Re: cub guys carb help needed
Posted by James Williams on December 01, 2013 at 15:59:15 from (24.126.41.180):
In Reply to: cub guys carb help needed posted by ericlb on December 01, 2013 at 10:43:23:
Check your carb and see if the float has a pin hole in it
jimmy
