Re: 350 farmall with continental diesel
Posted by Dieseltech on December 02, 2013 at 09:45:35 from (98.206.80.148):
In Reply to: 350 farmall with continental diesel posted by Lynn Willison on December 02, 2013 at 09:08:12:
With the pump removed use the slot to turn the drive shaft up out of the bushing, don't remember which way, but it will come out. The bushing is eccentric, and block pin holds it adjusted, turn it one way or another to set the drive shaft backlash. The bushing should lift out easy too. Replace the O ring under the bushing or you may have oil leaking also when it's back together.
