What do you mean the drive and injector pump are locked up. The injector pump drive gear comes directly off the camshaft. Doesn't the engine turn and if it doesn't how do you know the drive is locked up causing the problem? The pin is so you can adjust the gear backlash with the eccentric so there should be almost no backlash in the drive. As DeltaRed said, you need a manual as that is not a simple system. Roger
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
