Re: 706 gas missing when hot
Posted by charlieu on December 02, 2013 at 16:29:50 from (216.188.209.50):
In Reply to: 706 gas missing when hot posted by clint s on December 02, 2013 at 15:44:38:
I'm (ALMOST) sure that your manifold gasket is leaking. Take a 9/16 box wrench and try to tighten up the bolts that fasten the manifold to the cylinder head, you should notice a difference in how she is running. This is a common problem with the 6 cyl engine. If the miss goes away with the manifold tight you may be able to get by untill spring when gasket replacement will be required. good luck
