Re: 300 Utility Rear PTO question
Posted by Janicholson on December 02, 2013 at 21:31:28 from (74.60.94.18):
In Reply to: Re: 300 Utility Rear PTO question posted by bmagee on December 02, 2013 at 20:03:43:
They are tough. Just being out of the tractor can and will let the bands hang at an angle, or be without lube from sitting. It will be OK when put together. One critical element is to have no lost motion in the linkage. Any looseness will cause the lever to fail to move the internal linkage as needed. Jim
