Re: 706 gas missing when hot
Posted by D7fever on December 03, 2013 at 05:27:27 from (108.8.192.253):
In Reply to: 706 gas missing when hot posted by P T Farmer on December 02, 2013 at 15:44:38:
if all the other suggestions don't work, check your valve lash, if too tight ,when hot will hold the valve open
