Re: Still trying to get sickle mower apart.
Posted by TractormanNC on December 03, 2013 at 09:15:18 from (108.72.58.200):
In Reply to: Still trying to get sickle mower apart. posted by paul shuler on December 03, 2013 at 05:30:01:
Last one I did I had to take it to a hydraulic press and press it off. IIRC it is a VERY tight press fit between the shaft and crank/hub/pulley. The shaft then comes out the FRONT where the four bolt cover is.
