Posted by Owen Aaland on December 03, 2013 at 14:39:01 from (216.47.35.11):
In Reply to: start on farmall m posted by mkirsch on December 03, 2013 at 05:42:35:
There is no voltage drop in any circuit unless it is a complete circuit from positive to negative. The points make up the switch to open and close the circuit. With the points open there should be no voltage drop anyplace in the circuit. If there is a voltage drop across the coil with the points open then you have another path to ground other than the points. That may be a short in the coil, bad condenser, or short in the wiring between the coil and points.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development
... [Read Article]
Latest Ad:
[More Ads]
