Re: Cub PTO Cycle Mower belt pulley
Posted by mkirsch on December 04, 2013 at 11:06:12 from (65.199.189.6):
In Reply to: Cub PTO Cycle Mower belt pulley posted by Buddy C Norton on December 04, 2013 at 05:39:45:
Not much. It's cast, so it will not flex to clamp down on the shaft. It will just crack.
Take it off and look inside. Probably the splines are all wallowed out from being run loose in the past...
About the only thing you can do is use a "beer can shim" to take up the slack.
