Re: coil and ballast resistors
Posted by butch49 on December 04, 2013 at 18:25:27 from (67.142.166.27):
In Reply to: Re: coil and ballast resistors posted by Janicholson on December 04, 2013 at 17:21:33:
the reason I was thinking of changing the coil and loosing the resistor is with the resistor the voltage at the coil was low through the resistor
