Super A Steering Problems
Posted by Ron on December 10, 2000 at 05:13:40 from (209.240.200.114):
Aquired this tractor which had
spent the last few years taking
care of some local baseball fields.
The tierod ends (??) are badly
worn ,these I was able to order
thru local dealer at $52.00 each. He was unable to locate the upper piece ( part tha comes off the
steering box that the two tie
rod ends set side by side ) nor
the adjustment bushing that fit
on each side of the ball joints.
Sorry about sketchy discription
but don't have the ITT manual in
the house. So if any one knows of source or has any suggestions I
sure would welcome the help.
There also has to be a better
book Than those damm ITT manual
when working on these old tractors?????THanks ron
Post A Followup
: Re: Super A Steering Problems
