Re: Dealing With Kick-Back
Posted by gene bender on December 04, 2013 at 22:03:57 from (207.177.56.213):
In Reply to: Re: Dealing With Kick-Back posted by Bob on December 02, 2013 at 23:16:02:
If you take the cover off where the gears are that drive the rotor you can change the rotor a tooth by moving the gear. That H-4 mag is made to fire on TDC. When you have the front cover off and the dots lined up the rotor will fire on TDC like its supposed to just worked on one that went to 12v cause it wouldnt start the reason was the rotor was off a tooth.
