Re: Help with distributor
Posted by Bob on December 05, 2013 at 08:42:11 from (64.255.159.192):
In Reply to: Re: Help with distributor posted by sony224422 on December 05, 2013 at 05:36:13:
Here's a Delco, although not on an "H"....
Here's your IH distributor... (The casting # you posted is of the DRIVE, a part that would be the same whether there was a mag or a distributor attached to it.)
And, yes, you can crank it, so long as the base timing is et correctly.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
