Re: starter trouble 300 U
Posted by old on December 05, 2013 at 08:42:33 from (209.86.226.59):
In Reply to: starter trouble 300 U posted by 300dave on December 05, 2013 at 05:51:30:
You should be able to with your fingers spin the gear out. If you can not do that pretty easy it maybe gummed up with oil and grease ans dirt. The starter drive (bendex) need to be good and clean and free of grease and oil. And yes they do go bad and they can be fun to replace due to having to mess with the brushes. If you replace the bendex your better off doing the bushings and brushes all at the same time
