That is a near nothing resistor. It is rated at one ohm and is adjustable. Which means that the collar with the terminal can be moved up and down the resistor to adjust the series resistance of the path to ground in the regulator. Because one ohm is near nothing, and because it id slid all the way to the bottom, that resistor is doing nothing. If you take it out of the circuit (disconnect one end) I bet it reads just a few tenths of an ohm. Taking it out will make no discernible difference. Jim
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
