Re: B voltage regulator revisited
Posted by gene ender on December 05, 2013 at 23:36:55 from (207.177.56.213):
In Reply to: B voltage regulator revisited posted by fixerupper on December 04, 2013 at 20:06:02:
Did you follow the instructions that came with that reg. It is made to replace the cut-out on the 1101423,355 Delco Remy three brush gens and you no longer use the wire going from the field to the lite sw resistor. But the new wire is for the lite circut. I had one of those regs on a B that i sold later on and it worked OK. There was an article about those reg from the pres of the company who makes them in Red Power Magazine.Does your gen have the adjustable third brush if not you dont have the correct reg.
