Re: IH560 hydraulic woes
Posted by MaxDamage on December 06, 2013 at 08:14:35 from (208.53.248.253):
In Reply to: Re: IH560 hydraulic woes posted by John G. Hasler on December 06, 2013 at 06:04:29:
I did open all the drain plugs and let it sit for a couple of days while draining, I also had the loader and 2-point in the up position, then dropped them after the sump was empty to remove as much oil as possible. Unfortunately, it doesn"t take much water (maybe 300ppm) to saturate the oil, and ice crystals will destroy a hydraulic pump in very short order.
I"ve not tried the extra 5 gallons trick yet. I think I may after one more change of the filter.
