Re: IH560 hydraulic woes
Posted by The tractor vet on December 06, 2013 at 08:50:22 from (75.19.119.134):
In Reply to: Re: IH560 hydraulic woes posted by MaxDamage on December 06, 2013 at 08:30:08:
Your wasting your time tryen to let the water settle out . also the other killer on condensation is starting your tractor on a cold day and working it just long enough to get it sorta warmed up do what you need to do then go park it as it cools down it will sweat on the inside and make more water as you did not get it hot enough to cook the water off. So if you do not have a nice warm shop to keep the one tractor you need in the winter warm and dry it is a up hill battle . To get as much old oil out of the system you are going to have to drain all the cylinders and hoses on the loader and drain the rest of the tractor and refill . Then with many filter change it will get better and you filter change rate will be needed a lot more. . When the bad weather sets in my buddy and i have gone to usen just one tractor and the rest are put to bed unless something comes up and we need something bigger . for winter we rely on the 706 gasser as it will start nomatter how cold it gets I change the hdy filter just before the first really cold snap and we keep a half dozen filters and new gskts. on hand just incase . For loader work that is for the LX 665 New Holland with the CAB AND HEAT .
