Re: H gas tank
Posted by rustyfarmall on December 06, 2013 at 12:53:05 from (208.126.186.41):
In Reply to: H gas tank posted by GWS on December 06, 2013 at 11:24:34:
There is a WIDE opening at the top, and there are several holes in that baffle as well. That small gap at the bottom is why you want to use the muriatic acid. It will dissolve that rust and crud. Nuts, bolts, rocks, or anyting else you can throw in there WILL, and I repeat WILL get caught in the small gap, and trust me, you will NEVER get those lodged pieces of hardware back out.
