Re: Is this a crazy idea
Posted by CharlieU on December 07, 2013 at 05:06:17 from (216.188.209.50):
In Reply to: Is this a crazy idea posted by notjustair on December 06, 2013 at 20:11:40:
third party image
third party image
third party image
I just finished up replaceing the gasket on a Farmall H this week. In the first picture you can see the gasket is broke out in the 8 o-clock
position. I just used Ultra gray gasket sealer to repair, I did not use a gasket. I removed the PTO and loosen the bolt that holds the bull gear to the axle, working through the hole. Time will tell how good the Ultra gray sealer works.
Today's Featured Article - Product Review - by Staff. When we finally checked out the 3000 PSI North Star, the whole story chaned. This unit was equipped with an 11 HP Honda engine with fuel shutoff, adjustable flow and optional syphon degreaser dispenser. It didn't have a pressure release or electric start to facilitate easy starting but according to the instructions, simply pulling on the trigger while cranking was sufficient. This method of starting proved more than adequate and kept the cost down on the unit. It had all the important ... [Read Article]
