Re: Log splitter
Posted by Shetland Sheepdog on December 07, 2013 at 14:04:40 from (71.168.81.216):
In Reply to: Log splitter posted by GaryH1 on December 06, 2013 at 16:47:38:
Just a suggestion if I may, Go with the 23 GPM Prince pump, not the 11 GPM! The 23 will give you good splitter speed without having to run the tractor at full PTO speed. I have a 4' splitter with a 4" cylinder that works great with the tractor running just over 1/2 throttle.
JMHO, BTDT, HTH, Dave
