Posted by gene bender on December 07, 2013 at 15:24:37 from (207.177.56.213):
In Reply to: h mag. posted by ken house on December 06, 2013 at 16:21:06:
easy to pull the mag just remove rite after it trips and then check the rotor position so when you reinstall have the rotor in the same position and you will be fine i do it all the time it will be much easier to install points just like other post said DO NOT remove the front plate with the TWO screws as that cover is where the rotor is timed at. The Three screws removes the cover for the points. You can turn the mag backwards easy to set points just have the rotor pointing at the same position when you removed it to reinstall.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
