Re: Is this a crazy idea
Posted by heavyhaulertoo on December 07, 2013 at 17:17:24 from (173.215.4.36):
In Reply to: Re: Is this a crazy idea posted by Janicholson on December 06, 2013 at 20:26:00:
You are going to trim the sealer off the outside of the housing?
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
