Re: diode for 12v bypass
Posted by Janicholson on December 07, 2013 at 18:26:11 from (74.60.94.18):
In Reply to: diode for 12v bypass posted by gary in neb. on December 07, 2013 at 18:05:31:
Difficulties!
If your H has a saddle mount starter switch, it is tough to put a bypass on it. If it does, let us know and I can help get a solution. If it has a big push button you are in business with a diode. One good number is 276-1661 radio shack it is 6amp 50piv It will provide the starting voltage to the coil bypassing the resistor but not allow reverse flow to the starter. The stud on the switch that connects to the starter is correct, the one to the battery will not let it shut off. Jim
