Re: diode for 12v bypass
Posted by soundguy on December 07, 2013 at 19:06:16 from (207.30.46.70):
In Reply to: diode for 12v bypass posted by gary in neb. on December 07, 2013 at 18:05:31:
if you have the hard to get to switch.
in a hidden location, just install a simple push button switch.. momentary SPST.. 2 wire swoitch.. with contacts capable of 4a.
install tthe 2 switch wires ACROSS the resistor.
pressing that button while starting bypasses the resistor.
if you need 2 hands to start her ( feather choke, etc. then change that to a push on / push off latching switch.. hit it.. start.. hit again.
