Re: 560 Farmall Overheating
Posted by notjustair on December 08, 2013 at 07:57:59 from (174.238.68.115):
In Reply to: 560 Farmall Overheating posted by Bubba Marty on December 08, 2013 at 06:21:35:
Take the thermostat out. If it can still overheat in this weather you will know you've got problems. Is it really getting hot or is a bad head gasket pressuring the water out? I know it happens, but I have never had an IH hot - quite the opposite.
If you leave the rad cap off and watch it are you seeing the cold antifreeze be exchanged for steaming antifreeze? Is the top hose hot to the touch? What is the guage doing? When you say boiling out the water do you mean in the engine or the entire radiator?
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
