Re: 560 Farmall Overheating
Posted by Janicholson on December 08, 2013 at 08:10:36 from (74.60.94.18):
In Reply to: 560 Farmall Overheating posted by Bubba Marty on December 08, 2013 at 06:21:35:
One sure way to get to the heat of the issue is to "look" at it with a infrared/laser thermometer. They are 31 bucks at Home Depot (on line info)
As it warms up, keep checking the block, the head, and all parts of the radiator for heat. It will show the location of the rise in temp, or uneven temp in the rad core. If it is intermittent as you describe, A hose split on the inside and flopping shut like a heart valve is possible. Using a combustion gas detector kit from an auto supply store is also cheap and will rule out head gasket or cylinder head cracks into combustion. Jim
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
