Posted by robgIN on December 08, 2013 at 11:33:31 from (76.208.4.10):
In Reply to: Wedge plate on H posted by Dave S. on December 07, 2013 at 21:26:28:
if it is to reduce steering effort it would be thick part forward to put negative caster into the steering , which would aggravate a high speed wobble. If it is to reduce high speed wobble would be thick part to the rear to put positive caster in the steering for increased stability but would increase steering effort. The simplest illustration of caster angle is a bicycle, the front forks are farther out at the bottom than the top creating positive caster increasing stability so when you take your hands off the handlebars it still wants to track straight. If you reverse the forks it is hard to keep straight and if you take your hand off you eat asphalt.
