Re: Farmall Distributor-What Am I Doing Wrong???
Posted by Centex Farmall on December 09, 2013 at 12:12:07 from (72.105.166.18):
In Reply to: Re: Farmall Distributor-What Am I Doing Wrong??? posted by Pappy on December 09, 2013 at 08:39:52:
I had a problem one time on an old set where the terminal/wire junction was corroded. You couldn't really see it until you pulled the boots off.
If the insulation is old the spark can punch through to the block or other metal but since you have it out on the bench that doesn't seem likely.
