Re: '42 H Carb Help
Posted by old on December 09, 2013 at 12:16:33 from (209.86.226.54):
In Reply to: '42 H Carb Help posted by Farmer Matt on December 09, 2013 at 10:25:03:
Sounds like your over choking it. Only takes a moment of holding her choke on to do the job of you even need to choke it. Or you have the float set wrong or the float is not floating or the needle is not seating as it should be.
Also you need to make sure you have a good blue/white spark that jumps a 1/4 inch gap or more
