Re: '42 H Carb Help
Posted by old on December 09, 2013 at 15:06:24 from (209.86.226.57):
In Reply to: Re: '42 H Carb Help posted by Farmer Matt on December 09, 2013 at 14:59:45:
If it ran when you parked it the timing will not have jumped out of place. Timing is almost never a problem unless some one pulled the distributor off the tractor. One thing you should check is the air cleaner since you said it sat a long time the air cleaner maybe clogged up
