@mstas: I removed the filter and this screen for diagnostic purposes and there was no discernible difference in performance. Filter and screen ruled out.
@thefarmhand: All o-rings that are in or around the MCV have been replaced and all still look ok.
@JimB2: I don't know how this valve works, but it seems to me that if it were malfunctioning, I would lose steering pressure while lifting the loader but is it also possible I would lose pressure everywhere? When the pump got weak initially, I always still had steering and the loader would still go all the way up and down just off idle. It just didn't have any lifting power. Now, no hydraulics will work at all between Idle and at least half throttle. No steering, no 3pt hitch, no loader, no aux... the pto is good and strong though I have no idea how this is engaged.
@Harold Evans: The only way I know to bleed the air is to remove the flow divider valve and start the tractor until fluid flows continuously. Which I have done... is there more to it?
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
