Re: International 140 electrical issue
Posted by Janicholson on December 10, 2013 at 08:36:45 from (199.17.6.160):
In Reply to: International 140 electrical issue posted by Randy in Va. on December 10, 2013 at 08:26:05:
First make sure that the battery is disconnected. Put a test light between the terminal, and the battery cable. It will light up but not burn up.
Pull the big wire off of the alternator output stud. If the test light goes out, the alternator had a bad diode bridge. If it didn't, then begin looking for direct shorts to ground on the non grounded (positive) battery lead. Jim
