Re: Plow for f-12
Posted by Ron W on December 10, 2013 at 08:47:59 from (216.11.184.78):
In Reply to: Plow for f-12 posted by Dave S. on December 09, 2013 at 16:24:29:
I have several f-12/14 and plows, and have done
many a plowing with them.
My grandfather bought a f-12 with a single 18"
bottom lil' genius back in 1935. He farmed 80
acres with it along with a team of Morgan horses.
We have sandy loam, swamp land, but very little
clay. I rebuilt the tractor when I was 12, and I
am still plowing with it in third gear on the
sandy loam, second in the swamp land, and first in
heavy clay. I like to use this plow for deep
turning or sod busting because I can drop it deep
in the ground.
I have pulled a double 12 with this tractor in
sandy loam in second with ease. There are no
special pistons in the tractor, nor modified carb,
just the same OEM style parts. I do put in about
a quart of kero-or-diesel-or-fuel oil for every 5
gallons of gasoline to make up for the lead
removed in the gas and keep the rings from
sticking when they sit.
I do have a triple 12 plow, and tried it once
behind a f-12. Best I could do was first with
wide open throttle in that sandy loam.
Now you can have a good tractor, but if you don't
set the draft lines right, you'll loose traction,
waste horsepower and it won't pull s!@#. If you
can get a hold of a McCormick Deering plowing
handbook, it is very valuable in setting your plow
up right.
Keep in mind that comparing an H or M to a F12 is
like comparing a f350 to a f150 in towing a goose-
neck. The F-12/14 is a great little tractor; it
was designed to be smaller than a regular/f20, and
is comparable to having a team strong Morgans or
light Percherons (Draft Horses). I know this from
personal experience working with both. The
tractor was also priced lower for the small farmer
(20-75 acres)to afford. I have regulars and an
f30 and if I need the horsepower, I am happy to
use them. The f-12's though are very economical
on gas; even with plowing.
The right tool for the right job....
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
