Re: International 140 electrical issue
Posted by old on December 10, 2013 at 08:48:50 from (209.86.226.34):
In Reply to: International 140 electrical issue posted by Randy in Va. on December 10, 2013 at 08:26:05:
Things that will cause that are.
#1 install the battery back ward which means you have just fried the alternator so now you need to replace that
#2 the ignition switch is stuck in the start position so the starter is trying to spin up. Then #2.5 the starter is also lock into the flywheel so it is jammed and can not spin but puling lots of amps.
#3 a dead short due to some wire that has gone bad and goes right to ground
