Posted by S2710 on December 11, 2013 at 06:00:17 from (207.190.76.146):
In Reply to: Re: Farmall H Parts posted by FBH44 on December 11, 2013 at 02:38:19:
When you put the seals in the bolster you get two pieces of pipe that will fit over the bolster shaft and the outside of the pipe is the same size as the seal and then you slide the two pipes on the bolster shaft and then place the seal on top and raise the shaft up in place and put the nut on to hold it. Then you slide the top pipe up to push the seal up to where it is suppose to be and use the bottom pipe as a slide hammer. When you do it that way the seal is square and goes right in with no bending.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
