Posted by GRAPE-DRANK on December 12, 2013 at 10:59:19 from (98.117.67.240):
In Reply to: Super A cylinder head posted by gene bender on December 11, 2013 at 10:23:33:
I used red power domed pistons Gene. My head and block were both milled. After putting the sleeves in a micrometer showed that the sleeves were just a tiny fraction out of spec. I can't remember but it was a teeny tiny number out of spec according to the service manual. Deck a d head were shaved and I has no clearance issues. I don't know the exact number, but I took a pic of the high spot when we measured. I'll try to find it.
To the OP. All the heads RTR mentioned is correct, but I will add in the rare chance you come across a 240 that will work too. I can't remember how many different valve train kits there are for the 113/123 c.i. Engine, but to piggyback on what Gene said, there is more than 1 kit out there.
I used a 130 block and a Super A head. 3 angle valve job, domed pistons and a shaved block and head. I might have only 20 horsepower, but man does it have good compression. With the exception of the freeze crack forming on the block these are really good engines.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
