Re: bondo ???
Posted by clint s on December 12, 2013 at 14:06:24 from (108.183.224.168):
In Reply to: bondo ??? posted by BigTone on December 12, 2013 at 10:58:51:
Bondo will not hold up to alot of heat. They do make high heat epoxies and I think I have seen a high heat type bondo. Depending on how big a job it is JB Weld may work well for you. Apply in thin coats and it can be sanded smooth. Of course like said above the best way would be to cut and patch
Here is a high heat filler type
http://www.adtechplastics.com/pc-18-31-p17-smcr-high-heat-resistant-filler.aspx
