nosIh is correct, they all had the round governor housing you show in your pic up until engine serial #QC8827.(march of 27) which has the more square housing and enclosed carb linkage. Even though you don't have a Pickering ball governor it is still an early "regular" Farmall and worth saving. The tractor serial number should be the same and the QC tractors were built at Tractor Works before the Farmall Works were completed and the serial numbers changed to the T prefix.
Now if I read your post right you want to use a 22-36 as a parts tractor? Other than nuts and bolts practically NOTHING will fit the Farmall. You need another regular or F20.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
