Re: Farmall H-gas and distillate
Posted by Tom Fleming on December 13, 2013 at 17:14:40 from (173.233.18.197):
In Reply to: Farmall H-gas and distillate posted by Dave8N in Pa on December 13, 2013 at 16:08:31:
The only reason to buy a distillate manifold would be to do a "correct" restoration. They are hard to come by in decent shape with the heat butterfly intact and working. So, if you are just interested in making her run right, buy a good used gasoline one, or a new one if your pocketbook allows.
On the valve front, I would take the valve cover off, and give all the valves a good coating of clean oil. Sea Foam. Blaster. marvel mystery oil. Really whatever your favorite oil is. I am not trying to stir up the penetrating oil (snake oil) debate, just giving you options. Personally, for something like sticky valves, I like MMO, but each has their own opinion. The important thing is to get the valve stems and guides thoroughly lubed. If the old girl has been sitting for awhile, a sticky valve is NOT unusual. Kerosene or diesel would work as well. Important thing is that the oil used is low viscosity.
I like to take the valve cover off. Give each valve a good soaking in MMO, while occasionally turning the engine over by hand. Making sure each valve is moving, and coated. Best way is coat, turn 1/4 rev, coat again, another 1/4 rev, and continue until you have turned her over through the whole intake/exhaust cycle for all 4 cylinders. you can even do it with the engine running and the valve cover off. either way, get those valve stems and guides lubed.
If that doesn't solve things, let us know and we can go from there.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
