The second mark is to set magneto timing. It retards the ignition timing so the engine doesnt kick back when hand cranking. Also, if you look about half way further around the pulley, you will see a mark by itself. If you line that up with the timing pointer, then look up in the weep hole in the bottom of the bell housing, you will see the grease zerk in the flywheel to grease the clutch pilot bearing.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
