Re: 756 starter problem only when cold
Posted by old on December 14, 2013 at 10:00:51 from (209.86.226.32):
In Reply to: 756 starter problem only when cold posted by cdb on December 14, 2013 at 09:08:22:
I do not know that tractor as such but for the most part a tractor is a tractor be it older or newer.
#1 you do not need to remove the battery but it is a good idea to unhook the ground side of the battery before working on it.
#2 Yes you should remove the wires from the starter. It will have 1-3 depending on the set up maybe a wire or 2 more just make sure where each wire was.
#3 remove the 2 or 3 bolts holding the starter in and then carefully pull the starter be careful it maybe be heavier then you would think it would be
#4 clean out the starter drive gear area with brake cleaner spray then blow out with compressed air. Then just do as was said just back wards as in 3-2-1
