If the starter spins and the engine is NOT turning you have a problem with the starter drive. The drive has a one-way clutch built in to prevent the engine from spinning the starter too fast when the engine starts and the drive is still engaged with the ring gear. You need to remove the GROUND cable first, then remove starter and replace or have somebody replace the drive. This old one-way clutch is not locking up to turn the flywheel.
Safety note.. When working with batteries around tractors, you ALWAYS want to remove the GROUND cable FIRST. If your wrench touches the frame when removing the cable you will not get any sparks. When connecting the cables back up, always install the GROUND cable LAST. This does not make any difference if you are dealing with a neg. or pos. ground system. You just have to check which cable is connected to the frame for ground.
The starter on a 756 does not use a Bendix style drive so it does not get stickie.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
