Re: Janicholson Timing marks on an H
Posted by Janicholson on December 14, 2013 at 13:18:41 from (74.60.94.18):
In Reply to: Re: Janicholson Timing marks on an H posted by Bob on December 14, 2013 at 12:57:12:
To get to the bottom!!!
A method of putting the piston at TDC is to use a stationary fake spark plug that extends into the cylinder to touch the piston. Then the crank is rotated (by hand only plugs out, battery disconnected) till the piston stops. A mark is then made on the pulley at the indicator.
The engine is rotated the opposite direction as above till again it stops. Mark is made as above. 1/2 of the way between these marks is TDC.
The purpose for the retarded position of the Mag timing mark is to limit liability when hand cranking. a kickback from any advance forward of TDC will be dangerous to the cranker. Jim.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
