Re: 706 joystick plumbing
Posted by DeltaRed on December 14, 2013 at 16:33:08 from (65.100.146.8):
In Reply to: 706 joystick plumbing posted by crystall allis on December 14, 2013 at 15:02:06:
With fuel in off position,bump the starter.Oil will flow.Then you will know which is pressure and which is return.
