Re: Farmall F12 hard to start
Posted by athol carr on December 14, 2013 at 19:24:41 from (115.188.3.223):
In Reply to: Farmall F12 hard to start posted by FarmallCT on December 14, 2013 at 15:51:09:
There is a filter on the inlet to the carburetor, check. If it is a gasoline tractor then if the carburetor is dry it takes quite a bit of cranking to get fuel to the carburetor. Most goes back to the tank. If kerosene or distillate there is the small header fitting at the rear end of the hood which could be used for priming. If it has the F-14 type starter tank then that is gravity feed for starting. My O-12, gasoline, takes quite a bit of effort if it has been sitting for any length of time.
