Re: HARD STARRTING 656
Posted by T_Bone on December 11, 2000 at 04:40:14 from (207.254.53.70):
In Reply to: HARD STARRTING 656 posted by charles on December 11, 2000 at 04:18:42:
Hi Charles, Glow plugs draw about 17 to 20 amps each, so if your meter shows enough amps for all, then I would check the conections at each plug., then check ground at each. It doesn't take but one or two bad ones to cause a hard start.
T_Bone
Post A Followup
: Re: Re: HARD STARRTING 656
