Re: Farmall F12 hard to start
Posted by FarmallCT on December 15, 2013 at 13:07:11 from (69.118.77.7):
In Reply to: Re: Farmall F12 hard to start posted by Ron W on December 15, 2013 at 12:45:37:
I usually just shut it down by putting the lever in the up position which is off but it still is hard to start even if i just shut it off and try to start it again. If I start it by hand it usually involves a bit of ether/starting fluid and sometimes that doesn't even work. Is it possible that it is getting warm enough that it is vaporizing the ether and gas when I try to restart it? It seems to get very hot ans some white smoke sometimes comes out of the carb and when i put ether in it sounds like it is boiling/vaporizing. Thanks for the help.
