Posted by MaxDamage on December 15, 2013 at 21:14:45 from (216.235.175.14):
In Reply to: IH560 hydraulic woes posted by MaxDamage on December 05, 2013 at 20:12:00:
After it froze up again this time (about 3 minutes of running) I drained the oil yet again, pulled the filter, and man alive was it clogged up. Just an icy slush all over the relief valve screen. The last 2 gallons to drain were very milky, though the first 12 or so were fairly clear. Turns out the ice floats.
Given I'll have to do this a number of times before all the moisture is out, I'm thinking of investing in a turkey fryer to use as an oil heater. I should be able to boil the water off 5 gallons at a time and simply re-use the oil until it drains clear.
Another possibility (thinking long-term here) is to switch to a mineral-based oil in the fall, run it a while and let that sit. Without emulsifiers, that oil should allow any moisture to settle out and be drained off. Then new hi-tran by end of October and hopefully that has it good for the rest of the winter.
I'll post on how well the turkey fryer and/or mineral oil ideas work.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
