Re: Picture of my new F-12 - fuel pump / sediment bowl question
Posted by James Williams on December 16, 2013 at 00:20:40 from (24.126.41.180):
In Reply to: Picture of my new F-12 - fuel pump / sediment bowl question posted by bmagee on December 15, 2013 at 16:34:17:
My F14 did the same thing,when I redone the tractor the fuel pump rod was wore out along with the fuel pump,so I welded the rod and it was a little to long and was pumping more gas than it should,and yes it did miss just a little.I than ordered a new rod then it wouldnt pump,so I put the old rod back in and added a extra fuel pump washer behind the pump to act as a shim,did this I think twice and the bubbles cleared up along with the miss.Just for fun when its running just start closing your sediment bowl down and see if your bubbles clear up
jimmy
